-   -   Bluetooth music through AMI 2G and 3G (https://forum.a8parts.co.uk/showthread.php?t=11391)
Oli18 28th March 2016 04:58 PM
Hi,
I wish I was better with electrics but this looks like a really smart way to play music through the current AMI using a Bluetooth dongle.
http://www.dognmonkey.com/audi/modif...nd-mmi-3g.html
Has anyone tried this? I bet you could wire the power to a switched feed so you don't need to plug in to the cigarette lighter.
Oli
PsYcHe 29th March 2016 08:51 AM
Pretty sure there's an official Audi A2DP adapter out there. If not, you can get the aux-in adapter and use one of the many 12v units available. Probably a lot less hassle.
Delboy 29th March 2016 09:01 AM
http://cdn.meme.am/cache/instances/f...x/55494429.jpg
Now what you want to do is this, this, this and this and reset :tuttut:
No thanks
Oli18 29th March 2016 06:36 PM
Came to the same conclusion in the end and went for the Fusion BT100 after reading up on mcs's post here:
http://forum.a8parts.co.uk/showthrea...9999#post89999
Thanks!
Oli
