-   D3 - Wheels and Tyres (https://forum.a8parts.co.uk/forumdisplay.php?f=51)
-   -   wheel width (https://forum.a8parts.co.uk/showthread.php?t=11619)
H-M3 10th May 2016 12:26 AM
wheel width
summer is here and wanted to upgrade alloys soon. Can you put wider alloys at rear or is that gonna mess the drive? Also whats the max safest width I can put on my 8? also what is the best offset for our cars?
harvmiester17 10th May 2016 05:48 AM
I have a staggered offset set of 20" BBS alloys on mine which are 11" on the rear and 9.5 on the front. If I knew how to post photos on this forum I could show how they look but I'm crap so I can't. The correct offset is most important to avoid any clearance issues. I've been running this setup for nearly 2 years apart from over winter with no problems at all. Hope this helps+++
H-M3 10th May 2016 10:30 AM
Oh wicked! I will love to see the pics. You can add as attachment using paper clip symbol above the texts. Or I can on my email?
harvmiester17 10th May 2016 12:44 PM
I'll post some picks when I get home from work, didn't realise it was that easy.
harvmiester17 10th May 2016 04:10 PM
4 Attachment(s)
Here are a few photos as requested.
harvmiester17 10th May 2016 04:16 PM
I have no idea why they are upside down, like I said when it comes to doing stuff online I am truly crap.
H-M3 10th May 2016 11:43 PM
Autoporn!
Damn that looks PHAT! Really like those rims, any rubbing issues buddy and what is the safest offset? is the 4.2tdi discs any bigger than usual?
cheers+++
harvmiester17 11th May 2016 05:57 AM
Ha thanks, it gets a lot of looks and comments. No rubbing issues at all, I used lowering links to drop it about 35mm. The discs aren't a problem but the size of the front calliper can be, I used 10mm spacers on the front to get the look I wanted and clear the calliper. There's still quite a bit of space around the rears and I tow my caravan with this set up with no issues. Can't remember the exact offset but I'm sure I've made a note somewhere so I will get back to you.:)
H-M3 11th May 2016 05:51 PM
Alloys
What brand alloys are they budz?
harvmiester17 12th May 2016 04:56 PM
They're genuine BBS LM alloys, I bought them used and had them recut and painted. They cost a small fortune new but you can buy very good replica sets if you look around.
