Successful update to 5570 (I think!) but missing functions now
Hi all
Me again, still a noob but less of a noob today than I was yesterday! After a false start due to my inability to burn CDs properly, Ive successfully updated my MMI to version 5570, I think. I say I think because the 'Version' screen that I could select on the bottom right soft key has disappeared - I cant find it anywhere! Is this normal? Are Audi working on the basis that if you don't have a Version screen you can safely assume you are on 5570? Also, my passenger mirror no longer dips when I select reverse (doesn't matter what position the mirror selector switch is in) - do I have to re-enable this in the hidden menu or VCDS? Cheers Adam |
Version screen has moved, its now in the car > systems menu I think
