-   D3 - Lights (https://forum.a8parts.co.uk/forumdisplay.php?f=48)
-   -   New windscreen-1, Auto lights-0 (https://forum.a8parts.co.uk/showthread.php?t=12115)
Audidothat 11th September 2016 01:17 PM
Hello all
I had a new windscreen fitted, all good, however now when lights are set to auto main beam is on all the time, quite annoying as the satnav stays dark.
I am assuming there is a light sensor in the rear view mirror assembly that has been fiddled with somehow?
Also, does the battery need to be disconnected for a windscreen replacement? I noted the time was incorrect and a few other settings were different when I picked the car up and wondered if that had effected the auto light settings?
Thanks.
Turbo Tony 11th September 2016 03:14 PM
Double check the light/rain sensor is mounted tight up to the screen and that there's no debris between the sensor and the windscreen. It's mounted above the rear view mirror.
