-   D3 - Interior Trims (https://forum.a8parts.co.uk/forumdisplay.php?f=47)
-   -   drivers side seat switch issue (https://forum.a8parts.co.uk/showthread.php?t=12269)
goldsax 31st October 2016 10:06 PM
can i confirm my thoughts.
drivers seat does not come forward when i push the seat adjustment switch forward.
however the seat comes forward if the memory button i pressed.so i know the motor is ok.
i presume that it must be the switch.
1) will the switch need replacing?
2) easy job?( prefer no two take the seat out)
cheers raj
M-A8 31st October 2016 10:30 PM
Well, I've had one 8 for a short while where switch wasn't the issue, it was the ECU which is about £80, easy to change but it will throw CP which is £60 on top, but easy to change.
Get a ratchet with a spline bit, can't remember what size, undo all 4 bolts on each seat which is really easy, tilt them back to gain access to ECUs, swap them over (passenger/driver) and see if it goes forward using switch, if it does then it is the ECU , if it doesn't then switch it is.
I've never changed a switch on them, but can't see it being a big job.
goldsax 1st November 2016 09:30 AM
thanks for the info re. ECU
nothing ever plug and play with a D3.
another weekend job .
thanks again raj
