-   -   a8 d3 dab install vcds programing?? (https://forum.a8parts.co.uk/showthread.php?t=12919)
karlcossy 21st April 2017 11:15 PM
fitted Bluetooth to my car and now bought dab tuner so I can remove the pure highway
could someone please help I have vcds plugged in ticked the 0f in can gatway but still does not see it I'm sure there is another part to do but just cant work it out trailed all over google but no luck
richardracer 22nd April 2017 08:03 AM
Retrofit dab tuner
Hi there,
I retrofitted a factory dab tuner to my 2006 S8 back in 2012. I used a T cable for the optical loop, a dual power lead from nearby device and a separate aerial lead for signal. When all connected, dab showed up in the source list with no need for any vcds coding. Hope that helps.
Richard
karlcossy 22nd April 2017 10:05 AM
thankyou Richard that would explain why I could not find anything on the net :)
ive just replaced it with nav atm to check it out ive got to pick up link cable today for it so fingers crossed
ill let you know how it goes+++
karlcossy 22nd April 2017 11:19 PM
update got all fitted now but vcds still cant see it and nothing on mmi so can only presume bought a faulty one from the bay :mad:
