-   -   Axels, Brakes, Suspension and Steering Repair Sticky (https://forum.a8parts.co.uk/showthread.php?t=13)
Conan_the_Librarian 21st January 2009 05:48 PM
Here we will post links to Axels, Suspension and Steering related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
To Start the Ball Rolling here are some classic links from Paul W's Audipages. This site can't be recommended enough as a gold mine of information about you 8.
Audi Pages Top Level
SUSPENSION ALIGNMENT
A8 alignment specs are - ryoung on Audiworld
S8 alignment specs are - ryoung on Audiworld
FRONT SUSPENSION
A8 Control Arm Replacement - Audipages
Replacing a front axle (noisy CV Joint) - Audipages
ARB Bush replacement - Mr K
CV JOINTS
Replacing Boot and Repacking CV Joint
- Audipages
CV Boot Replacement
- Squeeto on Audiworld
BRAKES
FL Wheel Sensor alternative hack - Ronin
Juddering Brakes - DJStrange
Rear calliper (Girling - D2) component photograph - R8dream
Rear calliper maintenance photos and here- Dezzy
Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
