-   D3 - Everything Else (https://forum.a8parts.co.uk/forumdisplay.php?f=64)
-   -   Anyone any idea why my Parking Sensor Display no longer appears? ... (https://forum.a8parts.co.uk/showthread.php?t=13111)
JulianHicks 13th June 2017 10:52 PM
I upgraded my 2005 A8's parking sensor ECU in February to the C revision that shows the display on the MMI screen. It worked fine since then until today, when I noticed that the display no longer appeared whenever I used Reverse gear or pushed the button on the dash :Confused:
I've scanned the ECU and there's no DTCs and the coding hasn't changed somehow, so I'm puzzled why it no longer works!
Code:
Address 76: Park Assist        Labels: 4E0-910-283.lbl
  Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
  Component: Parkhilfe 8-Kan H12 0030
  Revision: 00H12000    Serial number: 08720610203793
  Coding: 0301008
  Shop #: WSC 02313 785 00200
  VCID: 234588EDE204395F59-8076
No fault code found.
Anyone have any idea of any tests to try or settings to check please?
Julian
H-M3 14th June 2017 12:54 AM
try doing a reset of the mmi, also i recently noticed when battery low the settings can be lost you you should go to settings and see if parking graphic is selected on mmi.
JulianHicks 14th June 2017 11:59 AM
Originally Posted by H-M3 (Post 129109)
... go to settings and see if parking graphic is selected on mmi.
Thank you+++
I didn't realise there was a setting for the graphic display, as it had automatically appeared once I updated the ECU.
What do you know? It was turned off - which is a bit strange as I certainly never turned it off :mad:
Easily sorted ...
Thanks - Julian
H-M3 14th June 2017 05:41 PM
We learn new things everyday+++
