-   -   Brake line flare (https://forum.a8parts.co.uk/showthread.php?t=13300)
mattylondon 8th August 2017 09:46 AM
Brake line flare
1 Attachment(s)
I can't find a definite answer on the web, so can anyone confirm what I suspect that Audi / VW use the 4.75mm DIN bubble flare for the brake lines?
I need to fab the short line from the hose to the caliper, as highlighted.
MikkiJayne 8th August 2017 09:53 AM
I use standard 3/16" pipe with M10x1 fittings and an off-the-shelf double flare tool. I can't say for certain that's '4.75mm DIN', but whatever is on the car is nothing unusual ;)
mattylondon 8th August 2017 10:38 AM
I was looking at these tools to make the flare, each are different spec of either SAE or DIN
http://www.ebay.co.uk/itm/282485747422?
http://www.ebay.co.uk/itm/252308824962?
I could get a tool that makes all flares, but would have limited use with me. I can't think the Germans would use the American SAE so I'll go for DIN as it is the Deutsches Institut fur Normung after all +++
MikkiJayne 8th August 2017 11:21 AM
Oh I see what you mean now :) Its the DIN one +++
mattylondon 8th August 2017 11:28 AM
Great! Thanks for confirming +++
