A8 4.2tdi 06 - power steering level
Just got the lid off as it’s hard to turn when stationary. At min if even, anyone know how much I need to get to max?
Thanks chris |
Depends how low the resvoir is , here's the more important question ....where has the fluid gone ?
When fluid is cold it should be around 2mm above min mark.
When warm it should be between min and max mark. http://forum.a8parts.co.uk/attachmen...1&d=1487689042 http://forum.a8parts.co.uk/attachmen...1&d=1487689042 EDIT When cold it should be around 2mm below or above min mark so looks like your level is fine. What’s the mileage? Power steering pump is maybe dying? |
Did you sort this out? Trying to check my PAS fluid but bit of a pig to get to? Do I have to remove air box to access?
Yes mine was black, it was a pain in the ass to get too.
Air box needs to come off- I think I left the bottom of the air box in and was able to work around it. I had a Wee syphon lying about that I used to suck out the old stuff then just refilled. Give it a go |
U will need a funnel or something to refill
1 Attachment(s)
Pic of it
Cheers. How much did you use to refill and what oil did you use?
Can anyone send me a link to the exact pipe I need to disconnect behind the pass fog light grill to pump out the steering fluid? I know Marcin did a write up but just curious as my one is diesel and so not sure if the layout is identical to petrol. Thanks
