D2 side light bulb replacement
I've had a look and can't see a thread on how to do it. I've tried twisting both ways, pushing and twisting etc but still no joy. Help please
If I remember correctly, the bulb holder just pulls out, along with the bulb. There's no twist-lock mechanism. I think it just clicks into place. Try gently pulling on it.
FL / PF? I thought there was a spring clip. I take it you don't have the owners book?
PF = pre facelift (indicators are completely separate lamps)
FL = facelift (headlamps are one piece units including indicators) On fl versions sidelamp holder is a straight pull from back of housing |
Cheers. Mine is 52 plate so FL. I'll have a go tomorrow
If you've got the simple pull out holders they'll look much like the pic about 2/3 of the way down this page
http://forum.a8parts.co.uk/showthread.php?t=9336&page=2 These are bi-xenons but think the normal xenons take the same fitting on FL. |
That's right, it doesn't twist or screw. Just give it a wiggle and the bulb holder will pull out allowing you to replace the bulb.
Mine are a white colour unfortunately every time I've tried to take a pic to see what to do I can't get a decent enough one. When I get back from work I'll have a go at pulling them.
Cheers all |
