-   D3 - Body and Exterior (https://forum.a8parts.co.uk/forumdisplay.php?f=42)
-   -   Help with boot lock problems ... (https://forum.a8parts.co.uk/showthread.php?t=14073)
JulianHicks 20th April 2018 09:55 AM
I'd be grateful if someone could explain how the A8's boot lock works so I can try and diagnose a fault.
As of yesterday, when I shut the boot I no longer hear the 'clunk' as the lock operates so I guess something's wrong.
I have the motored version; if I push the button, the boot closes and then reopens.
If I manually close the boot, it stays shut [thankfully] but I get the warning on the DIS that the boot is open.
Thanks - Julian
Architex_mA8tey 20th April 2018 10:27 AM
Mine had the pull-down (soft close) motor fail on it and did that - did it have that on yours? could be the soft close motor itself or the cable running to it (this is different to the actual boot open/close motor) :Confused:
JulianHicks 20th April 2018 05:02 PM
2 Attachment(s)
Sorry, I don't understand what you mean by the soft close motor.
The boot motor and cable that open and shut the boot are fine; my problem is that when the lock mechanism in the boot door comes down to meet the locking plate, there's no longer a motorised 'clunk' as the lock 'wraps around' the locking plate pin.
I'm hoping that someone can tell me what triggers the motor activation and what could have failed on my car.
Thanks & Regards - Julian
47p2 20th April 2018 07:19 PM
I think there's a micro switch in the latch part of the lock (your first picture). I had the same problem and sprayed copious amounts of WD40 in and it's worked ever since
JulianHicks 20th April 2018 08:20 PM
Thanks for that suggestion; will have a look in the morning.+++
Julian
Architex_mA8tey 22nd April 2018 02:01 AM
2 Attachment(s)
Its called "Power Latching System" by Audi and has a bowden cable going to a small motor - see pictures attached.
tc4332 22nd April 2018 08:40 AM
Julian,
There are two motors involved.
The one that Neil has pointed out is on all cars and is the one that locks the boot.
The other motor is the optional one that powers the boot lid up and down. This is for idle folk like me. :D
JulianHicks 23rd April 2018 06:40 PM
So I've only just read the updates to this thread as I forgot I was going away for the weekend :o
It's my locking mechanism that's not working; I've just had a look and I still can't work out what's going on when the 'black box' on the boot lid comes down and fits into the slot with the pin in it :-(
[Although I do now realise there's some sort of cable that gets pulled somehow from a motor in the boot thanks to the diagrams above].
But I presume:
a) the 'trigger' for the process is the boot coming down and the 'hook' in the boot lid box triggers the motor that
b) gets the motor to pull
c) the cable that's attached to the pin in slot.
So I guess the problem could be in any of these parts? Does VCDS have tests I can run to see which bit may not be working?
thanks - Julian
PS Just realised that I've had a few DTCs in my VCDS scans in the last six months but couldn't work out what part that was.:(
Code:
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
  Part No SW: 4E0 910 289 A    HW: 4E0 907 289
  Component: Komfortgeraet  H04 0040
  Revision: 00400004    Serial number:  W040411110043
  Coding: 0000249
  Shop #: WSC 02313 785 00200
  VCID: 275D9CFD963CD57EF0-8072
  Subsystem 1 - Part No: 4E0 910 853
  Component: Heckdeckel  P14H06 0070
  Subsystem 2 - Part No: 4E0 907 719
  Component: Neigungssensor  H03 0020
1 Fault Found:
00892 - Switch for Trunk Closing Cylinder (F248)
            007 - Short to Ground - Intermittent
            Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 25
                    Mileage: 373302 km
                    Time Indication: 0
                    Date: 2017.11.02
                    Time: 09:22:08
paulrstaylor 23rd April 2018 08:26 PM
Can you not trigger the lock using the side of a large screw driver? Does it latch? Does the striker plate move down an inch or so?
HPsauce 23rd April 2018 08:40 PM
1 Attachment(s)
I know I have a D2 not a D3, but I've replaced my boot latch more than once due to (in my case) mostly microswitch problems (also broken nylon internals).
I certainly used the shaft of a screwdriver for testing locking and unlocking with the lid open, very useful trick. ;)
I don't know if the D3 latch is physically the same, but if it is swapping the microswitch is pretty easy and I have a couple of spare ones if it's the same.
