D3 coding help. Module 46 - Central Convenience
A quick request for a helpful D3 owner with VCDS...
I read up on a setting called 'SAE rear lights'. Basically when the brake lights are on and you indicate, that side's rear brake light will dim to normal tail light brightness until the indicator clicks off and it will go back to full brake light brightness. A bit American and kind of useless but I had to find out what it does. Anyways, I went to revert the coding back to normal rear lights and subtracting 2048 from the code doesn't seem to deactivate the SAE rear lights now. I just need to check with another D3 and copy your code from Module 46 - Central Convenience. Whether or not you have electric rear blinds is fine, I can just add or exclude +512 (Rear Shades) and all the other coding should be the same for every D3? :Confused: http://i63.tinypic.com/4lol5s.jpg |
VCDS creates a text file log when you change settings, so even if you didnt make a note of the coding before, if you sniff around in the VCDS program directories you should find an audit trail.....?
I have come across instances where the label files dont match up properly....
You can always reset the coding to 0000000 and add each bit in 1 at a time to see what actually activates what..... a ballache, but it worked when I was trying to code in a roof module recently +++ If I had a D3 handy, I would check for you, but alas I don't right now.... |
Looked in my VCDS logs, my old D3 was 0004317
Mine is 0004861 and I have rear blinds
0004861 rings a bell though, I'm sure I've seen it as that before when I was turning the locking confirmation beep on which changed is to 0005885, so will try that. |
