-   -   CV Boot replacement (https://forum.a8parts.co.uk/showthread.php?t=145)
Conan_the_Librarian 27th January 2009 04:08 PM
CV Boot replacement
Had a blow out and grease all around the inside of the wheel.
Can get Bilstien gaiters for £15, no name for £5. Anyone used generic gaiters?
PsYcHe 27th January 2009 04:37 PM
Never used them on the '8, but have on previous motors and not noticed any difference, but then again, probably never had them long enough afterwards. I'd think you'd still get plenty of life.
But for a tenner, is it worth the chance?
Mkoneman 27th January 2009 10:26 PM
£30 for the kit from audi.
boot, clips, greese, bolt
im a sucker for oem parts on my car :(
harpersimon 28th January 2009 10:07 AM
is there a prodecure for doing these?
Conan_the_Librarian 28th January 2009 12:52 PM
Hmmmmm Check the Sticky? :tuttut:
harpersimon 30th January 2009 08:54 AM
Er.. I did - and I don't see anything that says Gaiter replacement ?-Plenty of stuff about drive shafts and axles but can't see where it tells you how to remove the gaiter when one is split - assuming its part of taking the drive shaft out but don't see that comprehensively described either!?
** Update** - Found a CV replacement post by using the groovy Google search - which took me here
Technically this post is in the wrong section - should be moved to Axles and Steering with the other CV stuff?
Zip 30th January 2009 09:34 AM
Had another quote...
...from my local Mr Clutch (!!) at £60 each fitted. That is using silicon boots which are guaranteed not to perish.
May take them up on the offer....Audi wanted over £400!!
Zip
harpersimon 30th January 2009 10:08 AM
£400!! As above the parts are only £30 from Audi!! How much is Stealer Labour rates these days. Criminals
Conan_the_Librarian 30th January 2009 02:43 PM
[arnie voice]The Axel's, Suspension and Steering Sticky under CV Joints? :o
However, nice find, added to sticky[/arnie voice]
Mkoneman 30th January 2009 05:14 PM
thats criminal, its a 2 hour job max
id say if your thinking of doing it and not taken the upper control arms out before then get a new long bolt that holds them in they can become damaged trying to get them out, or take the wheel off a day before and spray them with a releasing fluid such as wurth rost off
