-   D2 - Everything else (https://forum.a8parts.co.uk/forumdisplay.php?f=62)
-   -   VCDS Scan (https://forum.a8parts.co.uk/showthread.php?t=14598)
Markiii 18th November 2018 05:30 PM
VCDS Scan
Fortunatley I have an old version of Rosstech VCDS that I had for a previous car
Thought I'd fire it up and see what it could pull from the S8
results below
Wednesday,31,October,2018,05:22:27:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
Chassis Type: 4D (4D - Audi A8 D2 (1994 > 2003))
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
02
Address 01: Engine Labels: 4D0-907-560-AVP.lbl
Part No: 4D0 907 559 AA
Component: 4.2L V8/5V G 0002
Coding: 10753
Shop #: WSC 02314
VCID: 6DD7BFEF27132C7640B-5072
WAUZZZ4D33N000903 AUZ7Z0A2018570
No fault code found.
Readiness: 0000 1101
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D57
Coding: 08397
Shop #: WSC 02313
VCID: 316F639FFBAB8896243-50E6
2 Faults Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
18264 - Throttle Potentiometer (G69)
P1856 - 35-10 - Error Message from ECU - Intermittent
Address 08: Auto HVAC Labels: None
Part No: 4D0  ö4D 0
Component: 4öö4D0820043Q
Shop #: A8-öA8-K
VCID: 8303795791974A0606F-2566
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 4D0-959-655-AI8.lbl
Part No: 4D0 959 655 T
Component: Airbag Front+Kopf 5001
Coding: 01417
Shop #: WSC 02313
VCID: 4383395751170A06C6F-5072
Address 17: Instruments Labels: 4D0-919-033-MYX.lbl
Part No: 4D0 919 035 BA
Component: KOMBI+WEGFAHRS.VDO D39
Coding: 00483
Shop #: WSC 56076
VCID: 66C5C0C302E51F2E011-5072
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D17
Coding: 15179
Shop #: WSC 02314
VCID: 428D3C534E0D030ECD9-4E42
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4D0 035 192 M
Component: RNS 4.2 H06 BNO 0102
VCID: 295F8BFFD37BF056EC3-4A3A
Address 45: Inter. Monitor Labels:
VCID: 55A7F70FAC8384B698B-5072
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00001
Shop #: WSC 00000
VCID: 0401FA4B1499CD3EBF5-4A9C
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 00216
Address 76: Park Assist Labels: 4D0-919-283.lbl
Part No: 4D0 919 283
Component: Parkingsystem A8 RDW D07
Coding: 01108
Shop #: WSC 00000
VCID: E8D94EFB88F1895EB3D-50E6
2 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
30-00 - Open or Short to Plus
01629 - Sensor for Parking-Aid; Front Left (G255)
30-10 - Open or Short to Plus - Intermittent
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 EC
Component: AG5 01L 4.2l5V RdW 1010
Coding: 00101
Shop #: WSC 02314
VCID: 6ED5B8E32A15D76E791-50E6
1 Fault Found:
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
End ---------------------------------------------------------------------
I'm not too worried about Address 35: Centr. Locks Labels: 8D0-862-257.lbl
as I'm pretty sure they were all related to my fannying around with getting the keys to work when I first got it.
For the other codes though any suggestions on likely causes?
I'm tempted to clear them all and see what comes back as I have no idea how recent they are and if any faults are still present.
all thoughts appreciated?
steamship 18th November 2018 07:10 PM
You've saved the current log, so do exactly that. If you choose the option to clear ALL DTCs, it may be worthwhile double-checking those addresses that had the faults to ensure they were cleared properly. After that, drive the car for a bit and then re-scan, and work from there.
HPsauce 18th November 2018 08:56 PM
I always go into each controller to clear the errors, the global clear isn't always reliable; and check afterwards by running another scan.
Markiii 19th November 2018 04:41 PM
thanks chaps I'll shall clear and see what comes back
