Engine ran a bit rough yesterday
I scanned my car with OBD-Eleven tool yesterday after hearing it sound less than delightfully smooth and discovered an engine code of P1107
17515 P1107 O2 Sensor Heating Circ.,Bank2-Sensor1 Short to B+ Any ideas on where this sensor is located? Had a quick browse through my copy of ElsaWin to no avail... The car seems to be running OK now. |
1 Attachment(s)
I'm assuming you have a PF A8 based on the year. If so, then it only has 2 O2 sensors, which the following diagram might help locate for you.
I am going to make two assumptions here: [1] My car has 4 sensors, and not two? (complete guess) [2] This is a sensor located somewhere along the exhaust pipes? Thanks for your response, steamship ;-) and a merry Christmas to all. |
FL has four - two in front of the cats at the top of the downpipes and two behind the cats. Bank 2 sensor 1 is passenger side front - just at the back of the cylinder head.
Dave will love you for that one! Looking at pics of the cats off my old car here:
http://forum.a8parts.co.uk/showthread.php?t=12234 You can see the passenger side one is, mercifully, part of the shorter cat so doesn't involve removal at the downpipe. Cat will potentially need to come off and much soaking of the thread to get it out. I don't recall it being an arse-buckling price either. Might just be possible to remove in situ A |
More fun for Dave
Thanks for your update, Adrian.
I'm sure Dave will take it in his stride... although having said that, I've noticed recently that my current A8L has started to display that unmistakable weird oil smell when a seal goes and it starts to drip on the catalytic converter. This was something my previous A8 suffered from. It's made me wonder whether the sensor is getting temporarily coated with oil from the aforementioned leak as I've had no rough running since? Let's see what DS Autowerks discover. |
Usually the burning oil smell is from a gearbox seal so much lower down than the front O2 sensors. The engine doesn't tend to leak where it could get on to the sensors, but it wouldn't hurt them anyway since the active bits are inside the exhaust pipe.
Note to self - pull finger out and do things instead of prevaricating
This one has come back to bite me on the bum....
Car started perfectly today and drove for around 6 miles and then I suffered a huge loss of power. I thought my gearbox was playing up and then I heard the engine running like a bag of spannners, like 3 or 4 cylinders instead of 8 so it was as lumpy as duck... intentional misspelling there. I eventually shafted the battery due to the countless attempts to get the engine to 'catch; as the engine simply wouldn't run normally and tickover was something around 200-300rpm. No power to move forward at all. Was able to switch the engine off and read codes which came back with the aforementioned issue with the O2 sensor/bank message so I'll have to arrange for a low-loader no doubt in order to get Helga back to a nice warm garage. RAC didn't pick up the phone, and when I tried to join the AA (as a back-up option), they told me it was going to take them until 01:30 to reach me so I kindly refused their offer. Dad came over in the diesel Clio and it managed to tow my limo/tank about 300 yards up the road to a safer place. My only advice from tonight's escapade is that I know now exactly how much work my PAS pump works, as well as the servo-assistance on the brakes and it took almost a herculean effort from my skinny frame to either brake or turn the steering wheel. I'll get the car back to the local garage. DS Autowerks is not an option at the moment but I will have to sort that out first thing in the morning, |
