-   D3 - Interior Trims (https://forum.a8parts.co.uk/forumdisplay.php?f=47)
-   -   Rear Lid Lining Removal (https://forum.a8parts.co.uk/showthread.php?t=14803)
CrozA8 12th March 2019 02:02 AM
Gents,
Having trouble locating the two fasteners that hold the grip moulding into the boot liner. I've followed the workshop manual for general body repairs but cant find/uncover these two:-
7 - Bolt, 2 Nm
❑ 2x per moulded recess.
:mad::mad:
Any help anyone??
Architex_mA8tey 12th March 2019 07:16 AM
Originally Posted by CrozA8 (Post 148655)
Gents,
7 - Bolt, 2 Nm
:mad::mad:
Any help anyone??
Page 269 of THIS DOCUMENT should help you - most docs are in the common faults thread of each seection (D2/D3/D4 etc) under "TECH DUMP" which is stickied at the top +++
tc4332 12th March 2019 10:44 AM
These screws are difficult to see. (They are items Nš 7 in the diagram and fit through item Nš 8 into item Nš 14.)
I lean backwards into the open boot.
Then look upwards and into the grip.
Using a strong torch/light you will see the recessed screws. They might be covered with plastic pieces to hide them.
The crosspoint head of the screwdriver in the toolbox will fit them.
I find it more difficult to get the so & so's back in.
If you open the document that Neil suggested in a PDF viewer you might find that the actual page is "279"
CrozA8 13th March 2019 07:18 AM
Yes had that document open but still could not find the damn things.
Chris
CrozA8 13th March 2019 07:24 AM
OK TC4332, thanks for your direction. I knew there was something I was not seeing and it appears to be the camoed screw heads. I too did sit in the boot but could not see them.
Will attempt the same with a 1000 watt light source.
Thankyou for your assistance to both gentlemen above.
Chris
