raising suspension with no engine
Hi guys. It's the first time I've posted since my 4.2TDI threw one of its timing chains. I still havent actually managed to get any time to start getting the engine out for repair but am hoping to get a start pretty soon.
Since it has been sitting for a few months now (battery disconnected) the rear driver side has dropped. There is obviously a very small leak in the air bag or associated pipework. Thing is, since the engine popped, the suspension won't lift. Is it possible to use VCDS to get the suspension into lift height (so I can get the jacks under to start lifting it high enough to drop the engine out) and lock it into jacking mode? Nothing seems to be labelled on VCDS for these cars so it's really difficult for a technophobe such as me to use! thanks guys |
Have you closed all the doors? The air suspension is paused while doors and maybe boot are open (or not properly closed)
Turning the ignition on should be enough to raise it as long as jack mode is not on. |
