Speed Sensor or not??
Firstly, hope you are all safe in the current environment.
I have just come back from a 3 week trip which took over 7 weeks as I ended up stranded with no flights! Anyway, that's another story, now to the car... My car was standing and when I realised I was stuck abroad, I got a family member to charge it up (was flat) and put some fuel in/take it for a drive. Car was fine and behaved itself with no faults (surprisingly) although I know there would be some under-voltage faults stored. FF to present day and I started the car and moved it onto the driveway ready to be washed, parking brake on. After about 20 mins I realised I had to go get some meds so jumped in the car, started it and BOOM the ABS/ESP/Handbrake fault lights lit up. I drove it around the block, no change. I then cleared all the codes but the ABS one won't go away. It shoes as N/S/R speed sensor intermittent signal but having read some threads I'm not sure if it actually is this or something else? Bit of a coincidence it's happened after standing for a while. I did do a scan but saved it after I cleared the codes (Doh!) and so will scan again tomorrow. Battery was charged again fully but fault persists. Fuses all checked on both sides of the dash, no problems. Any more pointers on what to check before I order a new sensor? Also, anyone know the OEM or should I just buy from TPS? My bonnet has also decided not to open but that will be tackled tomorrow fingers crossed.... Thanks |
What does the ABS fault say? Does the ABS work properly?
OK it has now thrown a hissy fit! I went to read the codes and see what is showing.
Firstly, the car doesn't have a N/S/R speed sensor, from what I gathered it's front left and rear right. I checked the N/S/R wheel and can't see one either. With VCDS I tried to see what the ABS module is showing and it can't communicate with it now...and this has thrown up lots of faults. Parking brake, ABS and ESP were already there but now also headlamp, jacking light is on, level sensor, etc etc. My guess is that the ABS module is faulty and the car cannot determine lots of other data because of this and so it is throwing faults. These modules just show as DTC not supported or cannot read (or something to that effect). Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000731 Shop #: WSC 12982 000 1048576 VCID: 2019E2C9F6C1A42B732-8074 3 Faults Found: 01316 - ABS Control Module 008 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 3 Fault Frequency: 23 Reset counter: 26 Mileage: 158728 km Time Indication: 0 Date: 2020.04.15 Time: 14:33:38 Freeze Frame: Voltage: 10.04 V Count: 231 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 133232 km Time Indication: 0 Date: 2015.09.24 Time: 00:02:20 Freeze Frame: Voltage: 10.46 V Count: 61 01312 - Powertrain Data Bus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 66 Mileage: 158728 km Time Indication: 0 Date: 2020.04.16 Time: 16:08:20 Freeze Frame: Voltage: 10.66 V Count: 20 Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT Component: ESP 5.7 allrad H49 0650 Coding: 0001927 Shop #: WSC 02313 000 00000 VCID: 2B0305E58F077773D60-807E 1 Fault Found: 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 012 - Electrical Fault in Circuit Gateway Installation List: 4L0 910 468 A 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Cannot be reached 1100 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 |
OK hissy fit over lol. I walked away and left it before I had a cardiac arrest! Went back to the car and all the other faults have disappeared again. Can communicate with all modules and it seems more and more like the ABS module is at fault. I am guessing the control module is part of the ABS pump? Can't find any with my part number, so I may have to remove it and send it away for repair if it is at fault. Here's the scan
Thursday,16,April,2020,18:25:51:09330 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4 Data version: 20200331 DS317.0 www.Ross-Tech.com VIN: WAUZZZ4E28N009544 License Plate: S8 Mileage: 158730km-98630mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77 VIN: WAUZZZ4E28N009544 Mileage: 158730km-98630miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 1010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 552 G HW: 4E0 907 552 Component: 5.2L V10/4V FSI Ş0020 Revision: 5AH15--- Serial number: AUX3Z0H0339315 Coding: 01060003190F0260 Shop #: WSC 00191 264 15243 VCID: 2615F4D194E54A1B09E-8072 1 Fault Found: 049441 - No Communication with ABS Brake Control Module U0121 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 4 Reset counter: 255 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:11:01 Freeze Frame: RPM: 644 /min Load: 20.0 % Speed: 0.0 km/h Temperature: 90.0°C Temperature: 45.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.462 V Readiness: 0010 1001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E2 910 156 C HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0030 Revision: --H04--- Serial number: 0117917 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2411EED9E2D9B80B17A-8070 1 Fault Found: 049442 - No Communication with ESP (Vehicle Dynamics) Control Module U0122 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:15:58 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT Component: ESP 5.7 allrad H49 0650 Coding: 0001927 Shop #: WSC 02313 000 00000 VCID: 2B0305E58F077773D60-807E 3 Faults Found: 00003 - Control Module 014 - Defective 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 012 - Electrical Fault in Circuit 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 907 181 A Component: FBS AUDID3 H12 0200 Revision: 02005112 Serial number: AUX3Z0H0339315 Coding: 0412672 Shop #: WSC 02313 785 00200 VCID: 58E98A29EE112CEB4B2-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 2411EED9E2D9B80B17A-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.clb Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300LY077590793 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 3A2D30A1705DDEFB5D6-806E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0050 Subsystem 2 - Serial number: 00000000054257 Subsystem 3 - Serial number: 0115.12.070000000100010049˙ Subsystem 4 - Serial number: 010049˙ 1 Fault Found: 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 67 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:22:20 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000139701 Coding: 0123001 Shop #: WSC 02313 785 00200 VCID: 1C61D639DAA980CBAFA-8048 3 Faults Found: 00819 - High Pressure Sensor (G65) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 27 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:19:10 00065 - Rear Left Footwell Heater (Z42) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 26 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:00:46 Freeze Frame: Voltage: 13.10 V 00066 - Rear Right Footwell Heater (Z43) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 26 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:00:46 Freeze Frame: Voltage: 13.30 V ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No SW: 4E0 910 279 S HW: 4E0 907 279 S Component: ILM Fahrer H16 0240 Coding: 0133121 Shop #: WSC 02313 785 00200 VCID: 38292AA94E51CCEBAB2-806C Subsystem 1 - Part No: 4E2 910 113 C Component: Wischer WWS D3 H60 0440 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00141886 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 Component: SG ext.Player H15 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 02399 823 56573 VCID: 2B0305E583077773D60-807E No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276V8001047 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2411EED9E2D9B80B17A-8070 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 552 G HW: 4E0 907 552 Component: 5.2L V10/4V FSI Ş0020 Revision: 5AH15--- Serial number: AUX3Z0H0339315 Coding: 01060003190F0260 Shop #: WSC 00191 264 15243 VCID: 2615F4D194E54A1B09E-8072 2 Faults Found: 005491 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158733 km Time Indication: 0 Date: 2020.04.15 Time: 15:04:45 Freeze Frame: RPM: 653 /min Load: 20.4 % Speed: 0.0 km/h Temperature: 90.0°C Temperature: 48.0°C Absolute Pres.: 1000.0 mbar Voltage: 12.827 V 049441 - No Communication with ABS Brake Control Module U0121 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 4 Reset counter: 255 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:11:01 Freeze Frame: RPM: 644 /min Load: 20.0 % Speed: 0.0 km/h Temperature: 90.0°C Temperature: 45.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.462 V ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0041154 Shop #: WSC 02313 785 00200 VCID: 2517F3DDE9E34103004-8070 3 Faults Found: 02213 - Function Disabled due to Brake Temperature 000 - - - Intermittent - MIL ON Freeze Frame: Fault Status: 10110000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 67 Mileage: 158732 km Time Indication: 0 Date: 2020.04.16 Time: 17:10:00 Freeze Frame: Temperature: 34.0°C Voltage: 13.31 V Bin. Bits: 00100010 01316 - ABS Control Module 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11111101 Fault Priority: 5 Fault Frequency: 5 Reset counter: 27 Mileage: 158732 km Time Indication: 0 Date: 2020.04.16 Time: 17:11:00 Freeze Frame: Temperature: 35.0°C Voltage: 10.88 V Bin. Bits: 00100010 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory - Intermittent - MIL ON Freeze Frame: Fault Status: 10111101 Fault Priority: 5 Fault Frequency: 2 Reset counter: 67 Mileage: 158732 km Time Indication: 0 Date: 2020.04.16 Time: 17:12:00 Freeze Frame: Temperature: 38.0°C Voltage: 11.78 V Bin. Bits: 00100000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 E HW: 4E0 959 655 K Component: Airbag 9.41 H01 4210 Revision: 91H01421 Serial number: 003CU0006XRP Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 2809FAE99EF15C6B3B2-807C Subsystem 1 - Serial number: 63328RB40346E335G Subsystem 2 - Serial number: 63428RB40346E32DO Subsystem 3 - Serial number: 63528RB40346E2AFY Subsystem 4 - Serial number: 63628RB40346E2DCZ Subsystem 5 - Serial number: 63729RB4030C466BP Subsystem 6 - Serial number: 63829RB4030C46B4O 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 67 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:15:58 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 A HW: 4E0 953 549 C Component: J0527 0410 Revision: 00H05000 Serial number: 90026073280160 Coding: 0112151 Shop #: WSC 02313 785 00200 VCID: 2615F4D194E54A1B09E-8072 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 981 F HW: 4E0 920 981 F Component: KOMBIINSTR. VDO H83 0620 Revision: D03 Serial number: AUDID3H0000486 Coding: 0048423 Shop #: WSC 53816 003 1048576 VCID: 2B0305E58F077773D60-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4L0-910-468.clb Part No SW: 4L0 910 468 A HW: 4E0 907 468 H Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 0200J07B0981FB Coding: F5F5DFFF717E1E00 Shop #: WSC 02313 785 00200 VCID: 2D070BFDB1137943C84-8078 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 67 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:15:58 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0020 Revision: 01000102 Serial number: 20112007223929 Shop #: WSC 00000 000 00000 VCID: 1F1BE135CBBF9BD34A8-804A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H46 0390 Revision: 00046002 Serial number: AUZ5ZBG4064368 Shop #: WSC 00000 000 00000 VCID: 1A6DD021D09DFEFBBD6-804E No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 D Component: KLIMA-STG. FOND 017 0230 Revision: 00000020 Serial number: 00000000064774 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 619FA7CDBD4BED233CC-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: User\4E0-910-553.lbl Part No SW: 4E0 910 553 L HW: 4E0 907 553 H Component: LUFTFDR.-CDC H07 6340 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2C0106F98A09704BDFA-8078 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 67 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:22:20 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 2411EED9E2D9B80B17A-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 M Component: MNS ECE H51 1060 Revision: 00000000 Serial number: 364AY087746358 Shop #: WSC 00149 210 93595 VCID: 3B2335A57F67E7F3460-806E 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 67 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:16:02 Freeze Frame: Bin. Bits: 1100 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000729700113 Coding: 0232932 Shop #: WSC 00613 210 85940 VCID: 1D67DB3DC1B389C3584-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 F Component: Türsteuer.FS BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 2019E2C9F6C1A42B732-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 E HW: 4E0 907 289 E Component: Komfortgeraet H10 0030 Revision: 00300010 Serial number: W040712180219 Coding: 0004861 Shop #: WSC 02313 785 00200 VCID: 2B0305E58F077773D60-807E Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel H06 0060 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 67 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:11:01 ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 D HW: 4E0 035 466 Component: BO_D3 H06 0320 Revision: 21S00002 Serial number: 00410070010684 Coding: 0000027 Shop #: WSC 02313 785 00200 VCID: 270BF9D593EF5313328-8072 Subsystem 1 - Part No: 4E0 910 465 B Component: BO_D3_SLAVE H31 0310 Subsystem 2 - Serial number: 01812070008204 Subsystem 3 - Serial number: 0218.12.070000000100030038˙ Subsystem 4 - Serial number: 030038˙ 1 Fault Found: 03016 - Motor for Front Right Treble Speaker (V345) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 5 Fault Frequency: 3 Reset counter: 68 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:22:20 Freeze Frame: Voltage: 11.90 V Temperature: 47.0°C Bin. Bits: 00000100 Voltage: 12.00 V Temperature: 50.0°C ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000009691 Coding: 0010111 Shop #: WSC 02313 785 00200 VCID: 1E65DC31CCB592DB41E-804A Subsystem 1 - Part No: 8K0 907 410 Component: EHL205.06.02KHT H02 0010 Subsystem 2 - Serial number: 1451557T04Z601 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 67 Mileage: 158732 km Time Indication: 0 Date: 2020.04.16 Time: 17:15:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 F Component: Türsteuer.BF BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 2019E2C9F6C1A42B732-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000731 Shop #: WSC 12982 000 1048576 VCID: 2019E2C9F6C1A42B732-8074 4 Faults Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 133232 km Time Indication: 0 Date: 2015.09.24 Time: 00:02:20 Freeze Frame: Voltage: 10.46 V Count: 61 01316 - ABS Control Module 008 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 27 Mileage: 158728 km Time Indication: 0 Date: 2020.04.16 Time: 18:08:04 Freeze Frame: Voltage: 10.25 V Count: 231 01312 - Powertrain Data Bus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 67 Mileage: 158728 km Time Indication: 0 Date: 2020.04.16 Time: 17:38:33 Freeze Frame: Voltage: 11.08 V Count: 20 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 67 Mileage: 158728 km Time Indication: 0 Date: 2020.04.16 Time: 17:11:02 Freeze Frame: Voltage: 12.73 V Count: 242 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: 290FFFED85FB656324C-807C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH01 0010 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 40 Mileage: 158728 km Time Indication: 0 Date: 2020.04.16 Time: 17:16:00 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 396A 087587354 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 313F178DAD2B1DA3ECC-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 E HW: 4E0 919 148 Component: R78 TVHybridDVB 0470 Revision: R0H06000 Serial number: 76300801113601 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 2517F3DDE9E34103004-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000019927 Shop #: WSC 00149 210 93595 VCID: 2019E2C9F6C1A42B732-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 2712210239 Coding: 344530393135313035412056413032373132323130323339 Shop #: WSC 00000 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: Türsteuer.HL BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 1E65DC31CCB592DB41E-804A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000900055800 Coding: 0252329 Shop #: WSC 02313 785 00200 VCID: 2019E2C9F6C1A42B732-8074 No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H46 0630 Revision: 00000000 Serial number: 00000712180174 Shop #: WSC 12336 024 394758 VCID: 3635249144453A9BB9E-8062 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4E0-910-441.clb Part No SW: 4E0 910 441 HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J7Z100T Coding: 1021302 Shop #: WSC 02313 785 00200 VCID: 5CE196399A29C0CB6FA-8008 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: Türsteuer.HR BRM005 0180 Coding: 0032751 Shop #: WSC 02313 785 00200 VCID: 1E65DC31CCB592DB41E-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08740734903481 Coding: 0321008 Shop #: WSC 02313 785 00200 VCID: 2313EDC5E7D7BF336E0-8076 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 2 Reset counter: 67 Mileage: 158734 km Time Indication: 0 Date: 2020.04.16 Time: 17:15:57 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4F1-910-336.lbl Part No SW: 4F1 910 336 C HW: 4F1 862 335 Component: BTA H10 0960 Revision: 00H10000 Serial number: 00000007554357 Coding: 0060001 Shop #: WSC 02313 785 00200 VCID: 2411EED9E2D9B80B17A-8070 No fault code found. End----------(Elapsed Time: 02:36, VBatt start/end: 12.8V/13.4V)----------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Gateway Installation List: 4L0 910 468 A 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 |
I'm not any car electronic wizard, but I replaced the battery in my car about a month ago, and it gave "millions" of faults when starting the car afterwards and the dash lit up like a Christmas tree. I was able to clear most of them with VCDS, but I think it was the ESP symbol that was still on after several attempts to clear the faults. The ESP symbol went out after driving a few hundred meters (and maybe I also touched the brake pedal a bit).
As your car has been without power and then being charged, I would try to disconnect the battery for a few minutes and then connect and see what happened. And by the way, was the charger connected the recommended way? |
Yes was charged correcty, I have a CTEK charger which has the eyelets connected permanently so it can't be charged incorrectly. The strange part is that whilst I was away and the battery went flat, it was charged and driven around 30 miles, was fine. Only when I came back did it decide (on 2nd start) to throw a wobbly. I think I will try it anyway as there is nothing to lose, it may reset itself (hopefully!) |
