help needed
so today i notice that my parking sensors no longer work , all i get is a continus beep from the rear and nothing from the front , any pointers please:Confused:
When that happens on the D2, it’s because one or more of the sensors has failed. You can check which one with a VCDS diagnostic tool. You can buy D2 replacements on ebay and they’re not too difficult to fit. Ditto on an A6 that I did recently.
As 'The Laird' mentions, use something like VCDS to locate the faulty one. From what I've read previously, if one fails on the D3 it seems to disable the lot.
If you don't have VCDS, people have suggested switching the ignition to the ON position, put it in reverse, and then either place your finger on the end of each sensor in turn and you should feel it or place your ear next to it. |
I know you looked into this, but definitely get yourself VCDS. These cars are pretty complicated and full of electrics. Well worth the money.
I had the same problem with mine a couple of years ago. VCDS miss diagnosed which one it was or I miss understood VCDS. ended up replacing the wrong one.
Second time round I used my ear. They are sonic sensors and so make a clicking noise like a dolphin. Although not completely silent, one was much quiter than the others. I managed to change them both without removing the bumper cover but the inner one's are much harder to access than the outer ones. Or the other way round, I can't quite remember. Either way, one is harder than the other. |
A cheaper alternative to VCDS is OBDEleven, which is an OBD dongle controlled by an app on your phone. It cost me about £45 from memory for both the app (+ licence) and the dongle. Mine picks up the fact that my inner left rear parking sensor is faulty. Which reminds me, I must get round to replacing it - it's only been a year or so now ;) The OBDEleven unit has also been able to recode my gearbox, which I enthused about in another recent thread on 'autobox peculiarities'.
