Mirrors keep folding
I have a new issue on the A8.. as soon as i start the car or turn ignition on the mirrors start to fold and it doesn't stop until I remove the fuse..
Would this be a wiring issue or more of a replacement module job? VCDS scan doesn't show any problems |
My initial thought would be a dodgy switch, so take out the drivers door switch panel, disconnect that circuit and observe.
I've done it several times but forgotten exactly how, I think you have to lever off the door handle shell from below first. Maybe some screws/bolts too? |
Usually the relay is full of water as its right under botang's hole. Relay box top left, I think number 362.
"I defer to my learned friend". Also a lot easier to get at and replace. :cool:
To anyone reading this in the future, the fault was caused by a water damaged relay:
https://i.ibb.co/zVjxKFv/Whats-App-I...19-09-35-1.jpg https://i.ibb.co/hcTvfHn/Whats-App-I...19-09-35-2.jpg Relay number 361 in the passenger foot well: https://i.ibb.co/hVPC3vf/Whats-App-I...t-19-09-35.jpg |
