-   D3 - Interior Trims (https://forum.a8parts.co.uk/forumdisplay.php?f=47)
-   -   Sunroof interior panel removal (https://forum.a8parts.co.uk/showthread.php?t=16455)
quattronutter 14th October 2021 01:51 PM
How does it come out,just swapping in an alcantara roof and new sunroof
steamship 14th October 2021 02:03 PM
Check out from page 245 of the following PDF, assuming of course that you haven't already done so:
29-Service Manual General body repairs interior.pdf
quattronutter 14th October 2021 02:54 PM
Cheers yes already checked that out! cant get it to budge
tonupkid 14th October 2021 08:32 PM
If your asking about the panel in the roof of a D4, that holds the sunroof switch and other stuff.
Open the sunglass holder and look up inside it and you will see the head of a bolt. Remove that and then the entire panel slides backwards IIRC and falls off.
quattronutter 14th October 2021 09:52 PM
The sunroof shade panel,not sure if taking the glass out gives access to pull it out from above?
quattronutter 15th October 2021 04:59 PM
Glass panel out and comes out the top if anyone needs to remove in future
