A6 2014 2.0 Petrol - Opinions?
My son who lives in the Netherlands is considering a 2014 Audi A6 Avant
S-Line 2.0 TFSI . What are the thoughts on the 2L TFSI engine/car? https://occasions.audi.nl/#/occasion...ing--trekhaak- |
Run screaming from the 2.0TFSI. There are so many stupid and catastrophically expensive problems with that engine its not 'if' it breaks and writes off the car, but when.
The timing chain tensioners are a standard VAG issue, and when the plastic pads break they destroy the head - the fix is a whole new head at 3K + fitting. The high pressure fuel pump follower wears through and destroys the cam and pump - guess what? New head obvs. Also some generations around that age had a problem with piston rings and burn oil almost as fast as fuel. A lot of them were done under warranty, but if not you can imagine how expensive that can get. I would rather get the bus than own )or look after) anything with that engine. Its actually worse than the 2.5 V6 TDI, which is quite a feat! https://c.tenor.com/fTqq_sy-zLUAAAAC/screaming-run.gif |
:ROFL:
many thanks MJ. Your advice has been passed on +++ |
Ok, so which is the best engine for the A6?
Best overall is the 3.0TDI - the biturbo version is a beast. The 2.0TDI is ok but has issues with balance shafts, but is quite frugal.
For petrol engines, the 3.0 TFSI supercharged V6 is excellent. There is a 2.8 FSI V6 but tbh I'm not even sure we got that here. Other than needing their intakes cleaned from time to time, I've not heard of any significant issues with the FSI V6s. |
Whereabouts are you going? tbh he was only dipping his toe into the market having previously relied on public transport and bike but he now requires a car for work. So not sure how much help he could be but ill ask him and pass his details on by PM +++
Moving to Amsterdam. Pretty sure I don't "need" a car but not having one would be like losing a leg, and I want to be able to drive around the continent and back to the UK with the family (incl. a 3-yo) regularly! I have been considering something fairly basic like a Skoda Octavia, but the Audi forces are strong in the blood... |
im picking him up from edinburgh airport this pm so ill speak to him then+++ whereabouts in the 'Dam are you going?
