-   D2 - Body and Exterior (https://forum.a8parts.co.uk/forumdisplay.php?f=22)
-   -   Damned Parking sensors (https://forum.a8parts.co.uk/showthread.php?t=16706)
Markiii 13th June 2022 09:15 PM
Are on the blink again. No errors on VCDS but not a beep to be heard,
any suggestions chaps?
Ronin 13th June 2022 09:23 PM
what is the live vcds data showing? can you see the distances? it could be a blown speaker?
Conan_the_Librarian 14th June 2022 06:33 AM
A failed speaker will show in VCDS. Check the Fuses. Then as suggested hook up VCDS for the live outputs.
Markiii 14th June 2022 02:09 PM
thanks , chaps, it beeps if I press the parking sensor button the dash so doubt its the speaker. I didn't realise i could get real time info on them with VCDS, will give that a try
