Thermostat D2 FL S8
Hi All.
This is on a 2002 FL S8 Is the thermostat a timing belt off job? My local; specialist did the cambelt + last year and didn't do the thermostat. Now it needs doing and advised they need to take the cambelt off to do it.. I thought I had instructed them to change the stat, but cannot find any emails to prove....anyway what do to? Please advise. |
3 Attachment(s)
If you look at image 688, I've highlighted where the thermostat is, behind that metal pipework. Image 423 shows what's in front of 688, and image 680 shows what's in front of 423. Take into account that I also had the entire front end off the car, but I needed to do that. This is a 3.7 engine, but the 4.2 has a very similar layout. EDIT: Found the link, with video, but the engine is out of the car! https://www.audiworld.com/forums/a8-...-belt-2909229/ |
Many thanks.
In all fairness to the garage. They have agreed to do the stat at just a few hrs labour. the rest they will stand. Can we still get Audi thermostats? |
Great.
I will advise the garage. They did advise they wanted to use OEM Audi part. I will definitely not be supplying the thermostat!! |
Did they change the water pump? I thought that the water pump and thermostat changes were ‘standard procedure’ when doing the cam belt.
Hi.
Yes, they did the Water Pump....pullies, idlers etc. The instruction I gave was 'do everything. as I could see by the history that the belt was 9yrs old and the rest was original. Now also found as you look at the engine it needs left (so drivers side) front engine mount. Looks as though I can't get one from Audi any thoughts? |
1 Attachment(s)
https://www.ebay.co.uk/itm/145012897517 https://www.ebay.co.uk/itm/145159198886 Audi Tradition in Germany have the AT version: https://shops.audi.com/en_GB/web/tra...rm=4D0199381AT |
Many thanks.
I'll try and see how I can get the one from Audi Tradition... Perfect. |
