front drive shaft
Hi all, would anyone be able to tell me the part number for Front Drive Shaft ( OS but I'm sure they're not handed) please.
2010 D4 4.2tdi Thanks in anticipation Steve. |
Thankfully they are not 'handed', but there are six different versions depending on engine spec. For a 4.2tdi, you should have a CDSB engine code.
If that is correct, the part numbers are either 4H0407271A or the later 4H0407271G. |
Thanks Sean! CDSB is correct. I'm guessing either the A or G suffix would be compatable with my 2010 car or is that purely a revision to the part itself?
Steve |
Yeah, A is the original, with G being a revision.
Thank you.
