-   -   Caliper sticking (https://forum.a8parts.co.uk/showthread.php?t=1902)
KPS 21st June 2010 10:34 AM
Caliper sticking
Hi guys,
The rear driver side caliper is sticking and causing the wheel to get very hot. Is this something serious and expensive? Also am I safe to drive with it whilst I hopefully get it to AVP which might be a month or so! I've had the discs and pads changed last week only!
PsYcHe 21st June 2010 12:28 PM
I'd say it's serious, but not neccesarily expensive.
A8parts would do you one for a reasonable price, but if you're handy with a spanner, then I'd take it off again and make sure it's not the handbrake mechanism seizing on first, then work the piston back in a couple of times to see if it moves freely.
KPS 22nd June 2010 11:51 AM
Thanks, i dont know if it is the caliper 100% but a lot more heat coming from that side. I think its the seal more than anything as it had new pads and discs last monday including a MOT so not sure hopefully its something minor but good thing I noticed straight away. I spoke to Ben @ avp and the first thing he said was the seal so getting that ordered and that will the end of that!
