bad vibration
dont no if this is the right section to put this in but here goes
when i put the car in to drive i get a realy bad vibration coming from all over the centre console where the gear lever is,with my foot pressing the brake,if i put it into neutral it goes off all while standing still,i can also feel it while traveling when i accelerate but not as bad any ideas guys |
Has the engine management light come on?
Can you do a VCDS scan? |
yer light is on thought it was afaulty cat it seems to get worse when i press the brake pedal:Confused:
I'm thinking faulty ABS. Can you feel the vibration through the brake peddle?
Torque converter??
yep i can feel it through the brake pedal any ideas
If the ABS control module is getting duff information from the speed sensors at the wheels it may be operating the ABS. Without looking I'm only surmising that what your feeling is the pulsing of the brakes because the ABS is operating. Can you do a Vagcom scan? An output test on the ABS module would help.
If not try removing the ABS sensors and giving them a good clean. I could of course be miles out as..................................:Confused: |
I'd have the gearbox/engine mounts checked as well...
had a recon on the gearbox 12 months ago so iam hoping it wouldnt go that quickly,funny thing happened last night the esp light kept flickering on and off does this indicate an abs fault,and were would i find the abs sensors if so to clean them cheers nick
