-   D2 - Body and Exterior (https://forum.a8parts.co.uk/forumdisplay.php?f=22)
-   -   double glazed windscreen (https://forum.a8parts.co.uk/showthread.php?t=2349)
m3csl 24th November 2010 08:19 PM
hi all..can someone tell me if the windscreen on a d2 s8 is double glazed because my my snooper 3zero radar detector cannot pick up satelites when sat on the dash.
regards
M3CSL
IT 24th November 2010 08:27 PM
All but the cruddest of micra-mobiles have twin pane laminated windscreens, so yes, it does, but the pre facelift S8 had a special layer in there for some reason made of god knows what which basically prevents pretty much any radio signal getting into the cabin....
Fortunately, they changed the glass after 1999 so now phones / gps etc all work fine !
tonupkid 24th November 2010 10:12 PM
I think the problem coating is a metallic layer deposited onto the glass (Inside the sandwich). The idea being to reduce the greenhouse effect inside your car.
All your windows will have this and, sorry Ian, but I could barely get my Garmin to work inside my 2002 S8. Opening the roof/windows cured it though :ROFL:
PsYcHe 24th November 2010 11:10 PM
Athermic glass if the name I beleive.
And sadly, not just the '8s had it. You see quite a few cars with that funny couloured windscreen. Manufacturers got wise to it and started to put an unprotected area around the mirror for GPS etc to be stuck on
m3csl 25th November 2010 04:44 PM
So theres no way to use a gps radar dedector
PsYcHe 25th November 2010 07:13 PM
Re-radiating GPS antenna. Put it in the boot, or under the wiper grille cover, then run the cable into the car and away you go.
Conan has one, though I think he's since put the gubbins into the position of the original GPS aerial as he uses TomTom.
Conan_the_Librarian 25th November 2010 07:34 PM
Yup. Bought one of these and spliced it into the ariel on the boot. Works a charm and can run multiple GPS units of it.
ainarssems 26th November 2010 05:42 PM
I had heat reflecting windscreen on my 1997 S8 and GPS did not work unless I stuck it to the drivers door side window which have been replaced with normal window. Windscreen was in the bad shape witl lots of scratches, pits and chips, I was lucky enough to get a brand new Genuine Audi windscreen from facelift A8 for £40 on e-bay( best offer down from £50 buyitnow ).
RS6 5th April 2017 09:50 PM
im having the same problems with anything GPS can't use my snooper at all :(
