-   D2 - Transmission (https://forum.a8parts.co.uk/forumdisplay.php?f=27)
-   -   Transmission Casing Diagrams (https://forum.a8parts.co.uk/showthread.php?t=3026)
AndrewGray 24th May 2011 10:03 PM
Hi,
I was wondering if someone could send me some diagrams? I am working behind the cup that the front driveshaft bolts into.
I have removed the cup and I am looking to remove the casing. I believe that all I need to do is remove the bolts most outer on the casing shown in the following picture:
http://i50.photobucket.com/albums/f3...7/CSC_0393.jpg
I am wanting to look at an exploded diagram first before doing this and make sure that it is going to come apart how I think it is.
The car is a 96 4.2 D2
Andrew
Conan_the_Librarian 25th May 2011 04:39 PM
Andrew,
What is it your trying to do? If it's the output seal change then you don't need to remove the casing. This may be of some use.
AndrewGray 30th May 2011 01:49 PM
Originally Posted by Conan_the_Librarian (Post 22225)
Andrew,
Hi, I have done the output seal change but I am needing to remove the casing to gain more access for another issue.
Any chance you could sort me out with some diagrams so I can see how to remove it? :)
Andrew
Conan_the_Librarian 30th May 2011 04:18 PM
E-mail sent.
AndrewGray 30th May 2011 10:54 PM
thanks! :)
