tyre pressure
I am now running 275/35/20 and have a different pressure in each tire. What PSI should have in each generaly for motoway and fast road driving ?
will also probably change to nitrogen before the german trip +++ |
275/35R20 Y 102
front = 2.3 bar / 34 psi rear = 2.1 bar / 31 psi +++ |
That sounds low.
Took mine to Kwik Fit and had all 4 tyres filled with Nitrogen for only £6.00 the lot |
that does sound low. i thought they would be about 40 psi :Confused:
I've got mine at 44psi but they are 265/35/20.
You need to get it right. Had mine to low and I've lost the outer edge Darren, did you sort the fingerprint reader? |
I run my 19s at about 36-38 psi, so 40+ sounds about right (does it not say inside the fuel flap?)
You having bother with the fingerprint reader? It's fiddly btw, make sure you have two or three fingers registered :) |
I'm doing 41 all round on my 255/35-20s
Zip |
My Kahns are run at 40psi all around but they are 25 and 30 profile |
Does anyone know what pressure I should run on my new 265/40R-20 on a D2 PF?
Thanks in advance /Jake |
I'd go wth 40-42 psi
