-   D2 - Lights (https://forum.a8parts.co.uk/forumdisplay.php?f=26)
-   -   Puddle lights (https://forum.a8parts.co.uk/showthread.php?t=3437)
captain 18th August 2011 08:41 PM
Puddle lights
Don't seem to work on the drivers side front and rear!
All other interior lights are fine. Even the centre interior light when drivers door is opened. Any ideas?
PsYcHe 18th August 2011 08:49 PM
Is it a single fuse for that side? Or maybe just that they've been used more often and the bulbs have blown.
captain 18th August 2011 09:17 PM
The fuse box has never seen so much action!
I will swap bulbs with the otherside tomorrow and report.
Dezzy 24th August 2011 01:04 PM
does the lights work in the footwell? Also the light in the rear of the door (the red one) do they work? I suspect not.
graynada 24th August 2011 02:03 PM
Does your lights on buzzer work?
captain 24th August 2011 05:57 PM
what makes you think that? havent been available when its a bit darker to test just yet
captain 24th August 2011 07:26 PM
no mate, it does not. any clue?
captain 24th August 2011 07:37 PM
Update:
Only one door fully works (passenger side rear) both red and puddle light are fine.
- All other door red light and puddle lights do not.
- Both front footwell lights do not work either (there aren't any in the back are there?!)
- The Lights on Buzzer does not work either.
- The dashboard indicator that a door is open WORKS and shuts off when doors are closed.
Next stage - check the bulbs with the working set, but I get the impression there is something else wrong here judging by peoples response. Fuse?
I think a comprehensive review of my fuse box is in order anyway....
graynada 25th August 2011 06:29 AM
If your lights on buzzer doesn't work either I suspect it is the door contact switch that is at fault. On the front doors the switch has 2 contacts, from memory one contact does the door open indicator and the courtesy light, the other the puddle lights and lights on buzzer. I'm not sure about the rear ones.
The door contact switches are part of the door catch. Theoretically they can be changed without changing the entire door catch but I don't think they are listed as seperate items. Either way it is a complete door dismantle to get to :)
Dezzy 25th August 2011 08:22 AM
I was thinking contact switches as mine sometimes work but mostly not. It's something i've not worried about, especially as i didn't want to strip the door.
I'd go with Graynada and say contact switches
