Standard Sub, how to put back?
As above.
ive removed it with the 4 bolts some time ago. go to put it back, but the 4 bolts dont bite into anything, and i cant get access to where the bolt goes to? someone help? |
Your all as useless as me.
Unless the retaining nuts have worked loose.. Does the sub cover come off to check? |
Yeah mean the cover on the shelf?
yeah that comes off easy to get to the connections which are there. i can even get the sub back into positon, but when i put the bolts in they dont lock into anything. perhaps the retaining nuts are loose, so how do you get them back in place? |
Just checked ETKA there and it doesn't seem to suggest there's anything that could go missing, though it says you should remove the rear shelf :)
easy removing the rear shelf? is there a pic with it so i can sorta follow the fixings?
