-   D2 - Sat Nav, ICE, Audio & TV (https://forum.a8parts.co.uk/forumdisplay.php?f=38)
-   -   rns-d navigation fault (https://forum.a8parts.co.uk/showthread.php?t=3533)
ukinvestigation 14th September 2011 02:07 AM
help needed please .
everytime i try to set a destination, my stereo turns off and on . tried everything , even swapping navigation discs, yet nothing is working . this has started since i changed the fuse....... i put in the correct code , so i know its not that..
do i need to reset the unit ?. if so, how do i do it
Nollywood 14th September 2011 08:19 AM
Do you mean the complete unit switches off, or just the navigation?
ukinvestigation 15th September 2011 07:12 PM
the complete unit switches off and reboots iyself . think the unit is an rns-c . it doesnt look like the rns-d .
ukinvestigation 19th September 2011 06:16 PM
1 Attachment(s)
the pic attached is the unit i have in my car, but is it an RNS-C or RNS-D ?
IT 19th September 2011 09:27 PM
RNS-C - You couldnt get the RNS-D on prefacelift, it didnt arrive until late 2000 +++
ukinvestigation 20th September 2011 07:55 AM
could i fit a kenwood or other double unit in the car?...... just looking at other options
IT 20th September 2011 07:58 AM
Dont see why not, physically it will fit fine, and wiring shouldnt be too hard... +++
ukinvestigation 20th September 2011 09:48 AM
i might just look at fittin a double din....... there again , not really bothered at the moment. just the fact that my unit keeps rebooting whenever i "enter destination" . if in enter destination manually , it works fine. but doesnt store anything. ever since i removed the fuse.... is there anyway of reseting the unit ?. or is it a case of using a Vag-com
IT 20th September 2011 09:52 AM
Rebooting like that simply sounds broken to me. Should never be a need to reboot an RNS-C/D, and if you wanted to, you'd just unplug its power for a while. Vagcom is unlikely to tell you anything useful.....
ukinvestigation 20th September 2011 10:09 AM
its really weird , if i go into setting and enter manually it works fine. but if i try on main satnav screen it switches off and starts again .......
