-   D2 - Interior (https://forum.a8parts.co.uk/forumdisplay.php?f=24)
-   -   Lost live feed terminal 30 to my instrument cluster (https://forum.a8parts.co.uk/showthread.php?t=3778)
RanjS8 2nd December 2011 05:54 PM
I was trying to change the instrument cluster but ended up losing power to my live feed.
I tried to check fuses in the driver's footwell but anything instrument related looks fine...can someone tell me where the wire goes...cos I tried chasing the wire back behind instrument cluster but it is very difficult to follow....
Any help in resolving this issue would be very much appreciated.
Ranjeet
RanjS8 9th December 2011 05:31 PM
Terminal 30 live feed on instrument cluster
Well my problem was a blown fuse...in particular location 4 in yellow block....I found it by doing a continuity test across all the fuses...
I attached one wire on the live feed from the multimeter and the other end I touched the tops of the fuses until one of them gave me a continuous beep...then I found my culprit...
This fuse had a completely random name on the fuse diagram...so it wasn't obvious this was the problem.
