rear seat entertainment questions
not having rse - can the people in the back watch tv and how do they control it, is there a remote or is it built in to the rear armrest.
They have seperate screens.. You can fit a remote control for the MMI (which standard RSE has), and then there's the AV inputs/outputs and the splitter unit too.
Diagrams are on ELSAWin. |
i saw reference to pinouts for av out, as well as the av in auxs that i already put in. so if i add the pins for av out and a splitter unit to my non audi screens this should work.
i havent seen a remote for the mmi mentioned anywhere, do you know how these are fitted? |
Should work :)
Not sure what else you need apart from the remote itself, probably a receiver of some kind too. |
just looked on elsa and around the web, looks like the remote function will work if you have a tv tuner. there is a small recessed button which can be used to hook up to the rf remote, still havent found a price for it though
