-   D2 - Wheels and Tyres (https://forum.a8parts.co.uk/forumdisplay.php?f=28)
-   -   Tyre pressure for standard 2001 S8 (https://forum.a8parts.co.uk/showthread.php?t=4691)
SyncroS8 30th April 2012 02:22 PM
I've looked in the book, I've looked inside the petrol filler flap (no stickers :-( ) I've even tried the 'Use the SEARCH Luke' function on the forum...
I've looked on the net with the reg number and I get various tyre pressures as well as various tyre sizes!!
What should I be running on my stock 245/45/18s?
MG
HPsauce 30th April 2012 02:38 PM
My flap says 32psi, 42psi when fully loaded.
SyncroS8 30th April 2012 02:41 PM
All round?
MG
HPsauce 30th April 2012 03:11 PM
Yes, all round. That's for 245/45/18 Avus wheels on a PF S8.
Though when I went to Le Mans, seriously overloaded with big blokes and camping gear, I only put 42 in the rears and about 36 in the fronts.
SyncroS8 30th April 2012 03:14 PM
Ok that's great thanks.
I'm surprised that they suggest putting all 4 tyres up to 42psi when fully loaded!
Most of the websites were suggesting that I should be running 245/40/18s... I was starting to wonder if I was going mad!
Have just put my summer tyres on :)
MG
barzya8 30th April 2012 03:38 PM
32 PSI or 2.2 bar all round with 2 people and luggage
Hope this helps +++
David
SyncroS8 30th April 2012 03:42 PM
Thanks David,
Could someone give me the part numbers from the stickers that I should have in the filler flap so that I can order them from Audi please?
Then I won't be wondering again!
Or... a photo of them would do for now.
MG
PsYcHe 30th April 2012 03:46 PM
I find it varied between 34 and 38 depending on the tyres I ran, some were noisier at lower pressures.
HPsauce 30th April 2012 03:54 PM
1 Attachment(s)
Here you go, been meaning to do this for a while.
You can probably just read the range of tyre sizes too.
SyncroS8 2nd May 2012 09:48 PM
Thanks all.
I'm running Bridgestone Potenza RE050A 245-45-18s. They're set at 32psi now. I can hear them more than I was expecting. I don't want to over inflate them and have the centre of the tread wear out prematurely.
MG
