A8 Center caps wanted code 4E0601025N
Hi all.
Someone was kind enough last night to relive my lovely car (D3) of its centre wheel caps.:mad: Iv phoned Audi and been quoted £130 which considering the wheels plus tyres cost me £380 on ebay is abit of a bitter pill, iv included the code in the title and i think they are the wheels that come on the W12. Iv phoned around some breakers and checked ebay with no luck. Im wondering if anyone has a set or can point me in the right direction to get a set Heres hoping Cheers |
Piccie would really help?
Look for a very cheap set on ebay that have lots of corrosion around the outer ring and remove the ring. +++
Before http://i219.photobucket.com/albums/c...h_P1040936.jpg After http://i219.photobucket.com/albums/c...h_P1040937.jpg Before http://i219.photobucket.com/albums/c...h_P1040939.jpg After http://i219.photobucket.com/albums/c...h_P1040938.jpg |
Thanks 47. im struggling to find ANYTHING corroded or not. Is there any other caps that would fit or is it likely that they are specific to the exact wheel. I fear the latter.
Not sure there will be anything else that will fit
Going out now to check it... |
The part number for the cap is 4E0 601 165 A
Dimensions are 145mm across the front and 60mm at the rear |
Here you go +++
Wow, top banana 47 thanks for the link. I wonder what the chances are of them being my original ones ha ha ha!+++
