-   -   How to remember to tighten all the bolts (https://forum.a8parts.co.uk/showthread.php?t=4996)
ainarssems 30th June 2012 05:43 PM
What they do manually assembling Rolls Royce is mark the bolts with yellow paint as they are tightened so that workers clearly see which are done and do not miss any. This is the method you can adapt yourself when working on own car doing repairs.
Conan_the_Librarian 30th June 2012 07:40 PM
A technique I use with an added attraction. Once the bolt is torqued down ensure your paint blob also touches the point on the chassis/block/body so you can see if it is coming undone! :o)
