Need Xenon Plus bulb sizes
Hey all, I'm in desperate need of the bulb sizes for the Xenon Plus lamps. I know the Xenon is D2R but I need the others (turn signal, sidelight, tap to pass). Thanks.
Turn signal is the same bulb as the standard lamps, so you should be able to use the ones in the holder already.
Is it the same as the ones here in the USA though? Which I believe is 1157?
