for sale 1989 309gti rally car
This may be moved i didnt know where to put it so....
I have for sale my 1989 309 gti its the 2 door coupe it has Full roll cage 1.6 close ratio gear box Fast road clutch Toyo proxy on the rear Max points on the front Its got bilstein suspention with a lowered rear tostion bar Drilled brakes and ebc pads Tera trip navigation computer Hydrolic vertical hand brake by pass Internal fuel lines Kent fast road cams Hella spot lamps Pair of sparco bucket seats 4 point harnesses All locks have been removed. Boot doors bonnet ect and have pinns Sun roof has been welded over and a plate put there There is also a 10mm sump guard and skid plate Full forrest spec exhaust (back box has a hole in it needs welding ) The car runs fine starts and drives it has no tax or mot and has been off the road for about 18 months. Its red The car needs some tlc and would be a great project for some one. Its currently set up for road so would make a great track day car i will get some pictures up asap tomorrow for every one Im looking for around £850 ish ono i need the space now where its kept for something else i need a little run arround car :) Thanks for looking |
Sold !
