-   D2 - Engine Bay (https://forum.a8parts.co.uk/forumdisplay.php?f=20)
-   -   Coolant Leak! (https://forum.a8parts.co.uk/showthread.php?t=5714)
gninnam 2nd December 2012 09:57 AM
Coolant Leak!
Just opened the garage doors and noticed a lot of water under the front of the car.:(
Popped the hood and the coolant reservoir has lost about an inch or so of coolant.:tuttut:
So will pop it in the air and have a look - hope it's just a hose that has started to perish.
Wish me luck:)
Architex_mA8tey 2nd December 2012 10:20 AM
Wish me luck:)
Maybe it's peeved at you cos you bought IT's 8 and relegated it! ;)
Hope it's nothing serious anyways Andy +++
gninnam 2nd December 2012 01:40 PM
No sign of any leak that I can see so far:(
Will continue to investigate !!
gninnam 2nd December 2012 06:36 PM
Could not locate any leak during my invetigation.:mad:
Away first few days this week, but will have a look when I get back and see if I can sus out what is going on
Goran 8th December 2012 11:29 AM
check out the dreaded plastic pipe, that was the cause of my coolant leak. Its between the oil cooler/filter housing and the engine block.
gninnam 8th December 2012 03:24 PM
Cheers mate - will have a look tomorrow :)
Norretal 12th December 2012 07:29 AM
Did you find anything? Just started to have a very similar problem myself (slow loss of coolant, no obvious leak) over the last week or so and it sounds very much like there's a common cause, the dreaded plastic pipe. Is it something I can replace on the drive by myself or does it need to be on a lift for decent access?
Thanks in advance +++
gninnam 12th December 2012 11:31 AM
Shoved it in the air again last weekend and could not get it to leak!!
When it was on the driveway about a couple of thimble's worth of water (showing my age...) under the car.
Looked at AudiForums site and they reckon you have to move a whole host of kit out of the engine bay, plus lose your engine oil and coolant to change the pipe :tuttut:
Will live with it for now and decide what to do next year.
Hope you have better luck than me.
Norretal 12th December 2012 01:14 PM
Thanks for that update, you've made my mind up for me, it can wait until it develops or it's due a service +++
The_Laird 12th December 2012 02:31 PM
Definitely prostate trouble. Go see the doctor! :)
