-   -   D2 FL problems (https://forum.a8parts.co.uk/showthread.php?t=5728)
oldnick 6th December 2012 02:44 PM
D2 FL problems
although a recent MOT had no advisories , the service carried out just prior to it by an audi independant elicited the following comments
front anti roll bar drop links worn
ok , passed MOT ok but at the moment the car is in my barn in france and just next door my neighbours workshop has every facility except a lift [ he just puts some wood on the blades of a fork lift instead ] ; so off to flea bay and
http://www.ebay.co.uk/itm/1x-ACP-Sin...item2c6a0facbf
also
http://www.ebay.co.uk/itm/AUDI-A8-94...item1c2c77ff01
which purports to say it is handed and fits the right front [ and the rear left ] on 1994-2002
so which is it ?
the other advisory says ....nearside front forward lower arm ball joint worn
so back to flea bay and
http://www.ebay.co.uk/itm/Audi-VW-4D...21005145857%26
which I presume is correct ; so I had a look at the sticky and looked at the clear photo's of stripping down the whole system ...made my vision blur !!
looks beyond my capacity as a mechanic [ anno domini has struck ] ; so simple question ...is it possible to change just this one part ?
Dezzy 7th December 2012 10:20 AM
It is possible just to change those bits but to be honest you're just as well change the lot, bolts as well, or at least the pinch bolts as i didn't and they kept coming loose.
If you got 1 or 2 gone the rest are not far behind unless they've been changed out one at a time before
You'll have to have the alignment done after anyway if you change 1 or all.
I had a full set from the bay for around 120 + del and have done around 50k on them and they have started to knock again now. So all in they done well really.
