-   D2 - Body and Exterior (https://forum.a8parts.co.uk/forumdisplay.php?f=22)
-   -   Inside boot release button not working (https://forum.a8parts.co.uk/showthread.php?t=5760)
3.7 slp 14th December 2012 09:22 AM
Hi all just to see what you think i have found that my drivers door piller boot release botton is not working:Confused:.....was thinking it could be one of the air lines next to the hinges on the opening....
.....i can hear the air coming out after i have started the car for a time...
Thanks all
The_Laird 14th December 2012 11:05 AM
What car is it? If it's a vacuum leak, wouldn't that stop the boot opening on the 'blip' button on the key fob too?
47p2 14th December 2012 12:05 PM
Make sure the key position on the boot lock is in the correct position before you look any further +++
Adrian E 14th December 2012 04:24 PM
The button in the B pillar and the remote use an electric actuator to release the boot - if it works on the remote (push and hold for several seconds) I'd be pulling the switch and testing the connections to see if there's a continuity fault. If not, it suggests the switch itself is faulty.
3.7 slp 15th December 2012 05:49 AM
sorry its a 2000 A8 qs 3.7.And yes that's what i'm thinking as it works evey time with the key fob
3.7 slp 15th December 2012 05:51 AM
Thanks did check and the boot key position is in the up- down position
3.7 slp 15th December 2012 05:55 AM
Cool thank you will give that a check over..it a new button as the old one feel apart a few months ago...the button dose light up.... but will take it apart and check it.+++
Is there anything else that i should check out
mannyo 15th December 2012 06:53 AM
When I got my A8 the switch to work the boot was broken. Got a replacement from the forum sponsors (A8parts) via ebay, and now it works a treat.
Was the replacement new or secondhand, if the latter then it could have failed.
3.7 slp 15th December 2012 07:48 AM
Good point this one was new from TSP in Leicester was about £15 or so. +++
green A8 1st January 2013 08:15 PM
Is your glovebox locked? if so this should 'knock out' the pillar switch. This trick has caught me out a time or two. It stops anyone with the service key entering the boot also.
Hope this helps.
Paul.
