Door Alcantara Trim
Does anyone know whether the Alcantara section of a door can be replaced/swapped between cars? I am looking to replace my door cards, but I want to keep my alcantara trim.
Its all one piece as far as Audi is concerned so you would probably need the services of a car trimmer to remove it from the old panel and re-apply it to the new one, or to match the existing green alcantara
http://www.vagcat.com/p/B291/867000.png |
Grrrrrr I best choose whether the . upgrade is worth it then. |
I have the option for some full leather door cards, which would make everything except the upper dash and door tops leather. |
another vote for keeping the green+++
Can you just buy some in the right colour and get a trimmer to fit it.
e.g. http://www.ebay.co.uk/itm/251208813368 Having had my (admittedly D2) cards off the alcantara does only seem to be glued in place! |
Well, rightly or wrongly, I decided not to upgrade to full leather doors and under dash as I did not want to risk the Exclusive inserts in my doors. I will just stick with the leather handles.
I think that the item that I will still try to change is to the S8 pockets so I can have the aluminium trim. |
Is there a trick to removing the top wood trims as I cannot afford to damage mine as they are not walnut and cannot be replaced easily. I can see that the trim is pulled off in areas, but has a slider on one end. I will be removing all 4 doors, so are they all the same too?
Any help would be very useful. |
