-   -   battery draining power (https://forum.a8parts.co.uk/showthread.php?t=6068)
carterleeds 23rd February 2013 06:02 PM
hi guys wondering if you could help.
if i leave the cars for about 2 days my battery drains, and i dont know why :(
the battery is brand new and right for the car, i have coded the battery in using vcds.
checked connections to the battery eveyrthing seems fine.
nothing seems on when the car is locked.
could it be the battery control ecu/unit thats gone bad?
thanks in advanced :)
limoncello 23rd February 2013 06:14 PM
just fixed mine with the same problem, see this thread
http://forum.a8parts.co.uk/showthrea...hlight=battery
carterleeds 25th February 2013 08:37 PM
ok cool. thanks for that. ive had this problem for like 6months since the new battery went in. where exactly do i have to look in VCDS? battery regulator??
so can i just ring up audi and ask them to update the battery ecu? will they know what im talking about?
limoncello 25th February 2013 08:47 PM
Leeds Audi will know, they just did mine
Check out the software on the battery Energy Manager or regulator on vcds
ie on the scan below the software version is after the H11 so is 0340
if your falls in to the category on the linked info, take it in and tell them the problem you have and you want the batt manager updated to 0590
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H11 0340
Revision: 00000000 Serial number: 00000000003460
Shop #: WSC 00847 210 56212
VCID: 204A67C6F3D8C23
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 390870U0EZ
Coding: 34453039313531303541205641303339303837305530455A
Shop #: WSC 00468 210 67755
No fault code found.
carterleeds 26th February 2013 12:23 PM
ok thanks will check and let you know how i get on :)
which audi did you use? leeds audi?
i got my parts from there for the facelift, i dealt with a guy called lance, very helpful guy, unlike some of the other clowns there. but if you ever need parts always ask for lance he knows what he is doing.
limoncello 26th February 2013 01:14 PM
yes leeds audi
the last part i went for was the update disks for mmi
i waited for them to come in
when they rang me i drove down there to collect they had lost it, said they would order another and post it to me, never did
carterleeds 26th February 2013 06:04 PM
it seems my SW version is not inbetween the uodate versions. however i did notice the H02 instead of H11 like yours. does this matter aswell?
Part No SW: 4E0 910 181 HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0160
Revision: 00000000 Serial number: 00000000001122
Shop #: WSC 00000 000 00000
VCID: DDB51D477DA1
well when i first rang up, a guy said sorry i cant take the REG plate i can only input VIN numbers so i left it because with the facelift upgrade i used autotrader for s8 reg plates. so anyways went in the following day and lance was there, and he happily took the reg plates and inputted them into the system and i got what i wanted.
limoncello 26th February 2013 07:18 PM
not sure what the H02 / H11 difference is, the tsb doesnt mention your very low software revision, it only states that 0240 didnt have an issue, but above did, it maybe worth a punt anyway, it shouldnt cost much and they can check whether your batterys still good and for any other drains at the same time.
you notice at the end it says how to check its Ok, if there is still an issue to track the part thats affecting it.
PsYcHe 26th February 2013 08:13 PM
Also looks like Limoncello's is a C rev hardware, may make a difference to the problem too.
I'd guess the H02 is a hardware revision 02 which if there was 'original' then H01, then H02 would lead us to C :)
