-   D2 - Everything else (https://forum.a8parts.co.uk/forumdisplay.php?f=62)
-   -   D2 Aircon valve? (https://forum.a8parts.co.uk/showthread.php?t=643)
JamesA8 27th March 2009 12:01 PM
D2 Aircon valve?
Hi all.
My aircon isnt working, the Pump dose not come on and its getting a bit like summer.
Dose anybody know were the location of the LOW pres. valve is in the system?
Any help would be great.
Conan_the_Librarian 27th March 2009 01:06 PM
Three possible answers here,
Does the clutch engage when you switch between economy mode and normal?
Is the system pressured?
Could the pump be U/S?
VagCom can test the clutch working if you have access to it.
Quick fit do an aircon service whereby if they can't reduce the temperature by 10% or more you get it free. Give them a try first which will bowl out under pressure if it works after they have finished
JamesA8 30th March 2009 07:49 PM
The clutch dose not engage when I go from econ to normal.
I know the A/C has a pres switch on it to protect the pump if the pres is to low, but if I cant find the LOW pres valve I cant see how I can check the pres.?
I did have VAGCOM till I dropped my laptop a week ago. I will have to try and steal a mate laptop to check the clutch.
Cheers for your help Conan (the Librarian).
