-   D2 - Transmission (https://forum.a8parts.co.uk/forumdisplay.php?f=27)
-   -   Gearbox speed sensor (https://forum.a8parts.co.uk/showthread.php?t=6613)
S4_Sat 24th June 2013 03:42 PM
Any ideas on where this is? Need to replace it as the speedo isn't working all the time.
S4_Sat 25th June 2013 10:50 AM
Anyone?
The_Laird 25th June 2013 10:56 AM
I think a lot of the gurus are away - the forum is pretty quiet. Try a PM to Goran and Adrian
rs32 25th June 2013 10:57 AM
does this help ? http://www.audipages.com/Tech_Articl...vereplace.html
Adrian E 25th June 2013 11:02 AM
What fault does it throw up and does it give a sensor reference?
I'm trying to sort out stuff for our holiday so a bit time short but if its definitely attached to the gearbox I should be able to find a PDF of the location and potential part number :)
Nollywood 25th June 2013 07:36 PM
It's on the transmission, passenger's side, just above and slightly ahead of the axle output shaft.
rs32 25th June 2013 08:23 PM
on that link I posted above..... 6 is the wheel speed sensor and 7 is the engine speed sensor +++
http://www.audipages.com/Tech_Articl...m_DSCN1303.JPG
