-   D2 - Common Faults (https://forum.a8parts.co.uk/forumdisplay.php?f=66)
-   -   Airbag light (https://forum.a8parts.co.uk/showthread.php?t=6979)
fireman dan 30th September 2013 05:06 PM
Airbag light
Hi. Have been told there is a link here
Somewhere for the seat occupancy to stop
The airbag light. Thanks.
HPsauce 30th September 2013 05:16 PM
If that's the cause, yes. It's somewhere in the appropriate section if you have a D2 S8. But what codes do you have?
fireman dan 30th September 2013 05:30 PM
Where's the appropriate section?
Thanks.
Architex_mA8tey 30th September 2013 05:40 PM
you probably want THIS THREAD. just take a look in the relevant sections and there is normally a repair sticky and an upgrade sticky at the top of each section with links to many regularly requested items! +++
HPsauce 30th September 2013 05:45 PM
Glad someone remembered it was in D2 - Interior Electrics.
Read through it and check what error codes you have and that it's relevant.
As I noted there (after a few pages) if it is just the front pad you can literally just short it out; dead easy and worth trying.
