-   -   Door latch switch (https://forum.a8parts.co.uk/showthread.php?t=7008)
David's8 6th October 2013 05:37 PM
Door latch switch
I seem to be getting an occasional error with the front passenger door switch which shows the door as open even when its firmly closed. Searching a few old threads provides the info that the switch is in the latch so can anyone advise what is involved in replacement? (apart from money... :( )
PsYcHe 6th October 2013 05:44 PM
Give it a good old squirt with WD and a couple of hard-ish slams, then see...
If it's the microswitch, then they're a bit fiddly to get the lock out, but not too scary.. Mostly just taking bits out the door innards.
David's8 6th October 2013 05:46 PM
Thanks Richard. I'll give Plan A a go. +++
